I was wondering if you would show up here.....
Basically, it's a long rod about 22" long that is locked to a bed anchor bracket at one end and the taper base plate at the other. It's purpose is to stop the plate from moving as the cross slide traverses back and forth on the taper attachment way.
The taper base plate basically hangs from a rear extension of the crosslide and the cross slide moves front to rear following a taper guide on the plate.
My rod is about 1/4" in diameter and
@Upnorth's is about 3/4 inches in diameter.
Mine is prolly adequate but its a weak link in the system. I can see no reason not to upgrade it to a 3/4 inch bar.
I have not done a buckling analysis. But my guts tell me that there will be a huge difference between 3/4 and 1/4, and further that shearing of the anchor screws is a non-issue. Here is a rendering of the parts:
The large beige block screws to the back of the saddle. The bottom plate is fixed in relation to the ways by the anchor bracket and the subject bar at the bottom left of the photo. Internally, there is a follow-block inside the large block that follows the smaller adjustable taper plate to move the rear anchor of the cross-slide leadscrew in and out.
To visualize the concern, I already suggested substituting the rod with a piano wire. Doing so allows anyone to see the problem. As the slenderness ratio improves with fatter rods, the assembly gets stiffer and stiffer.
Doing the math wouldn't be difficult if we knew the loads. I don't. That would require testing. Therefore about all I can say for now is that piano wire would surely buckle, a 1/4 rod might or might not be a problem depending on your definition of a peoblem, and a 3/4 inch rod would be a safe bet.
The OP
@S.Heron really just wanted to know what size of rod to use, and I suggested making it bigger than mine because the one on mine looked too small to me. When I saw how much fatter and shorter
@Upnorth's was for roughly the same size lathe, it somewhat vindicated my concerns.
Normally, I wouldn't get overly concerned about such things, but I'm particularly sensitive to the design and manufacturing issues of the taper attachment I just bought. It's VERY disappointing so far.
Post in thread 'Is Taper Attachment worth it?'
https://canadianhobbymetalworkers.com/threads/is-taper-attachment-worth-it.8860/post-156856
