After misunderstanding some of the advice here and the online calculators I am a bit gun-shy of repeating mistakes and having a wreck.
I have this little railroad anvil I made and have never worried about resurfacing the top surface of it as it really didn't matter much to what I typically hammer on about. But now I see an opportunity to try out a face mill I got with my machine but have hardly used.
I've tried a few online calculators and I know that they are a good starting point IF one understands them correctly. I did not understand things correctly last attempt so I am going to run my plan by the folks here first this time.
The face mill is 50mm diameter with 4 apkt1604 inserts. The railroad anvil is likey 1084 medium carbon steel.
My calculations say about 200 rpm and 3.25 ft/min feed rate. I'm not 100% sure I have all info entered right?
The depth of cut says .375" and width of cut says 1.867". Does that mean I attempt to remove .375" of material across nearly the entire width of the tool???
I will squirt wd40 as a lubricant as needed?
View attachment 31157View attachment 31156
