Gear repair
I’ve got a buddy with a broken gear from a boat drive train. This is 1.25” in diameter. Replacements are quite pricey. Anybody able to fix this with bronze or make a new one?
I suspect the gear in mesh with that one is pooched too. Spiral/bevel or mabe even hypoid so it would be very hard to duplicate with enough accuracy without using dedicated gear making tooling. Your friend probably already knows that a boat is just a hole in the water you pour money into so he will probably have to bite the bullet and buy the pair.
If it's available as a manufactured part it will be cheaper than having on repaired or custom made.
Hi John,
I would think that gear has hardened teeth given it is part of the main drive. I would always be wary that a repair failure might destroy more of the drive.
Make sure your friend also checks the meshing gear for damage and the shaft for any twist/bend.
Anytine you put “marine” or “boat” in front of anything the price seems to magically double .....
