Tom Fitzpatrick
Active Member
Coming back to the collective Think Tank for answers to questions. On July 21, 2025 our home in Okotoks, was struck by a massive lightening bolt at the lowest point of the garage roof which caused a fire in the garage roof. We were not home at the time, but 5 1/2 hours away. EXTREMELY QUICK ACTION action by my neighbour and the Okotoks Fire Fighters saved the house and most of the superstructure of the garage, but rendered most of my metalworking and woodworking equipment, tools, supplies and metal stock and wood inventory damaged from water and debris landing on it. Restoration began the next day and companies involved have emptied the contents to a safe location for cleaning and scrutinization. We are extremely LUCKY and THANKFULL to ALL involved in the SAVE.
Now starts the renovation project as of today, now that the garage is empty and a complete shell of its former self.
Several questions for the group:
1. I'm laying out the basic plan for my renewed shop by using the blueprints to re-position machinery (lathe, drill press, mill, tables, jointer etc.) for maximum efficiency i.e. use of the space and movement around the machinery and workbench, counters, and cabinets. I'm using cardboard cutouts of the machinery that can be saved to position them on the blueprint. Any suggestions for this process would be most welcomed.
2. The entire roof has to be replaced along with the entire truss system. I was building a gantry crane at the time of the disaster, but have another thought. I now have the opportunity to install an I-beam the width of the garage supported on 4X4 or 6X6 steel columns between the existing studs. This beam would be used as the gantry crane and because it doesn't support the roof structure, it only carries the load of whatever I'm lifting at the time. I was thinking of either a load of 2 tons to 3 tons would be the absolute maximum it would have to lift or hold. My question is, I realize there will have to be an engineer involved in the calculation of the size of this beam, but what I-beam tables or spec sheets do any of you know about that could help me get an approximate cost of this beam.
3. Any other suggestions on the renovation of this garage workshop would be welcomed from the group.
Thank you kindly for this and all of the past questions this collective Think Tank have helped me with and I will keep you informed of the progress.
To all things that produce smiles,
Tom Fitzpatrick
Tom Fitzpatrick
