Fusion 360 Help...
Richard Tymko
Hi,
OMG I need help? I am having trouble generating tool paths in Fusion 360 for the attached job file. The stock is 1.25mm thick sterling silver epoxied to a plexiglass base so it can be cut clean through. Each fox head needs to be cut out as shown in the extrusion.
I want each fox head to be a separate tool path. I made the attached link shareable.
I am using 2D adaptive and getting this message... Generation completed successfully in 1.1s. Warning: Empty toolpath.
The area thatI am trying to machine out is between the fox head and the tail and between the tail and the tail tip.
The other one in I am using 2D Contour and getting these errors when trying to cut out the entire fox head... Warning: A contour was not machined because the given lead parameters would cause a collision!
Warning: Lead-out is dropped due to linking constraint. Generation completed with 2 warning(s) in 1.5s.
http://a360.co/1ZM9lbU
Any help is appreciated, Thanks.
Richard
