Does the stand make your lathe more rigid do to increased weight? I like it, except I would maybe add some risers to give more distance to cleanout. This might be on the list from my welder friend. I am considering to move my Craftex lathe into the new shed (in design stages yet).. I also like the idea of stacking over it. This is making me think of using more feet for the height (14 is max). My square was upped to 16 x 10..So far the stand has been great, it's rock solid and the storage is super handy and I like having the ledge all around to set tools down. Only downside maybe is that chips are hard to clean out from under the machine, but that might be true of any stand.
Will the new mill stand incorporate a support for the table when it is parked on the far right?
We're metric in Canada also. I think then US is the only country that still measures things based on the length of the king's foot. (although we are very familiar with feet)China uses (metric) meters, which I roughly converted to: 3.28 feet =1 meter. My garage is about 7M by 7m (23 ft by 23 ft), there's another garage 12 ft by 20 ft that I use to install the machine tools, and there's some extra space that I can use to make shelves for materials, parts or whatever.
My site is about 70 square meters (800 square feet), which is probably a relatively large DIYER in China's DIY community, even a little extravagant. More than 98% of the DIYER's area is less than 10 square meters, or even slightly larger cities, very high housing prices have strangled the vast majority of mechanical enthusiasts.
My ideal studio size is 200 square meters (2200 square feet). Because my hobby is to create new products (inventions), or create some disruptive upgrades, or make some small improvements that are more beneficial.
The current space is not enough to support more mechanical equipment, nor to meet my machine tool requirements.
So if I lived in Canada, I would definitely choose a house with a large basement (of a certain height) and a larger garage.
I don't have much equipment right now because I don't have enough space to store it!
Hey Tom, I’d love to see some pics.We're metric in Canada also. I think then US is the only country that still measures things based on the length of the king's foot. (although we are very familiar with feet)
I'm much more to the messy side. A small double garage is my domain. Had to clean up a lot when I got a car that I need to keep inside. I'm currently going thought the many boxes of stuff I have in storage. Too many hobbies, too much stuff.
My "machine shop" is about 6 ft by 12 feet (2m x 4m). Room for 10" x 18" lathe, RF 30, Taig lathe, and some metal casting stuff. As I clear out space, I hope to keep it clear. As things are now it helps to know which foot you need to lead of with to make it through the maze.
Not really much more rigid but the extra mass helps dampen vibration further. Stand with tool boxes in adds somewhere around 300-350lbs, it's mostly 2" x 0.125" steel tube and has a 1/4" plate top (that alone is basically 100lbs). Building up is definitely a good idea if you have the height, make use of that space and also if you design it right can give you tool access and place to mount lights or even a little hoist potentially.Does the stand make your lathe more rigid do to increased weight? I like it, except I would maybe add some risers to give more distance to cleanout. This might be on the list from my welder friend. I am considering to move my Craftex lathe into the new shed (in design stages yet).. I also like the idea of stacking over it. This is making me think of using more feet for the height (14 is max). My square was upped to 16 x 10..
I like your welding setup (I'm still a welder-less widow). Dumb questions:
- is the middle shelf on the cart for accessories or is it bunk beds for future second unit like MIG + TIG?
- the blue, I assume portable/knock down table, is that what you use for welding work? If so, its it self made or started out as something else? How thick is the top surface?
I notice you place mats over your hoist. I'm presuming its to keep crud from getting in there. Probably a pain to clean out.
Holy crap, that's 100% accurate for me lol.
I am still pretty far away on this project. We need to dig starting in about a week, gravel, settle, tamper. concrete, build, wire, drywall, tape sand and paint... then move in ... I am thinking a rolling stand like yours, but add ballast, like either tool storage, or just dead weight to lower center of gravity. Since it rolls out and locks, I will be able to pull it out form wall to service. Added flat top and weight with good clearance below to clear junk out.Not really much more rigid but the extra mass helps dampen vibration further. Stand with tool boxes in adds somewhere around 300-350lbs, it's mostly 2" x 0.125" steel tube and has a 1/4" plate top (that alone is basically 100lbs). Building up is definitely a good idea if you have the height, make use of that space and also if you design it right can give you tool access and place to mount lights or even a little hoist potentially.
2 feet from spindle centerline to bottom of first shelf, about 19 inches from top of headstock. The first shelf is around 10 inches shallower than the other two above it, this helps make it feel more open above the lathe.I am still pretty far away on this project. We need to dig starting in about a week, gravel, settle, tamper. concrete, build, wire, drywall, tape sand and paint... then move in ... I am thinking a rolling stand like yours, but add ballast, like either tool storage, or just dead weight to lower center of gravity. Since it rolls out and locks, I will be able to pull it out form wall to service. Added flat top and weight with good clearance below to clear junk out.
How much space is above the headstock? I will consider a shelf 2 - 3 feet above, anchored well to the studs and with supports to floor, full 16 feet length along back of room, and room for second shelf above. I should be able to put light under the first shelf above the lathe. and have a total of 3 openings between the four supports.(for the shelfs).
Top one is in the middle, bottom isn't...bottom is off because of the way the old mill stand is built, it's indented at the front where the door is, so I centered that support on where the center of the storage space inside the stand is rather than overall center.I noticed that on your mill stand the (top & bottom) middle braces are – well, not in the middle. That seems odd, but I expect that due to your attention to detail, there is a reason. So??
They sure do 🙂 designed them both to use the same ones, saves me buying a second set, storing a second set, and building a second set! Also, got my engine hoist to the garage...took it apart and brought it up through the house piece by piece lol wasn't too bad actually, half dozen bolts and the cordless impact wrench made short work of it.Do the casters do double duty for the lathe and mill?
