Fire foundry
Bofobo
M,Mizera(BOFOBO)
With a bit of wood and some easy summer bevy’s I’ve spent the last bit of the year doing fire pit casting with my new crucible 0B6C1C84-256C-4B83-87D9-19ECE3EF98AF.jpeg i put the crucible on the ash bed in the middle and create a ring of fire around that, reforming the fire after a night of rain was the most time consuming part. B7C7157A-8A4D-4360-A363-D0F1DE6CB81E.jpeg When it’s time to pour it’s not as hot as the foundry so less bubbling and a tighter grain structure are noticeable when doing inspection breaks when still hot enough to break clean.
Tomc938
What size is that crucible? And how long from set in until melt? I have a 5 gallon furnace (propane for now) but I have seem 20 lb crucibles that would greatly expand what I could cast, and they just don't fit in! ;o)
Bofobo
M,Mizera(BOFOBO)
Great thing is it’s scaleable, this was a half melted arctic cat motor I salvaged, and I down sized it without a crucible in a larger fire
Tomc938
Not here, great for a fall or spring exercise in campfire wizardry
I will keep this in mind. Here in BC we have these awesome fire rings that are about .75 meter across. I bet they would concentrate the heat nicely - and I didn't see anything online about not being able to pour molten metal in your campsite!
