DRO for dummies (aka .... me)
Just would like to see 0.0005" as that's what I can measure :) ... So I guess I won't worry as much about 1/5micron.
Brad
Yes I'd go for the extreme resolution only if I could flip the extreme precision off for most cases and only on to see if I could impress myself.
Bradells
(BRad)
But then, knowing my luck, I'd end up with something that only shows 0.01 (had it happen before)
Brad
ersatz engineer
I own an indicator that reads in 2 micron increments; it is possible to accurately read to 1 micron with it. Probably useless for me, but I couldn't resist it ;)
Chicken lights
Forum Pony Express Driver
Ok I’m curious enough to ask...
In layman’s terms- I can choose different fuel filters to use, a 7 micron, a 10 micron then a 25 micron for example
Now obviously there’s (apparently) a 3 micron difference between a 7 and a 10, how the heck do you measure something that small?? I’m guessing that’s just a tolerance built into the fabric used as a filter some engineer somewhere specced
But still, 3 micron difference!
ersatz engineer
filter medium is measured statistically by running a solution with sorted particles and measuring the percentage of pass through to whatever standard is being referenced.
measurements of thickness is done using a Marr indicator that uses the twist of a square shaft about double the thickness of a human hair to amplify the difference in height.
surfaces can be measured quire accurately for straightness using an optical flat, up to 1/10 lambda, which in the middle of the spectrum is less than 1/100 of a micron.
... and there are dozens of other distance measurement techniques. The current quickest way to measure accurately to about 1/5 of a micron cheaply is to use laser inferometry....
ersatz engineer
So in an incredible coincidence Tom Lipton (oxtool) showed off his tool room inferometer in Monday Night Meatloaf # 127 , starting at 32:00 into the video:
