Chris Cramer
The arbor on the end of the shaft of my drill press is in terrible shape and doesn't hold the chuck well enough to keep it at the center of the shaft. If you look at the original arbor in the first picture the arbor is part of the shaft, so it is a tapered shaft. In this case I will need to cut the arbor off the end of the shaft and weld a new jt6 arbor onto it.
