Dreaming of a power draw bar
I'm telling you guys the portable power impact driver works great. No air. It sounds and looks like a joke but it's fast and simple. try it!
To use in the making of a PDB, or instead of?
I haven't seen one that would lend itself to adoptation into a PDB the easy way the butterfly wenches do
So my mill doesn't have any sort of spindle lock. Right now when I'm tightening up the draw bar I simply hold the pulley with the other hand. Is my spindle just going to spin with a power draw bar and no spindle lock?
Good point. Mine is the same.
The bottom end of my spindle does have two flats on it so I guess I could make a spanner for that if it does spin?
Although that's going to require 3 hands...1 for the powerdrawbar operation, 1 for the spindle wrench and 1 to hold the tool/collet in place. Hmnnn I gotta rethink things.
Oh boy I better go to bed, I'm not thinking clearly.
Why would the spindle turn if I can hold it with my hand on it just as well as holding it up top on the pulley?
Good night!
Ya, nothing to grab onto on mine either:( My mini-mill came with a locking rod and a hole to lock the spindle from turning.....
I think inertia just breaks those PDBs loose and sets them?
On mine you need to lock the quill fully up or the down force of the power draw bar will push it down and not allow full engagement of the socket onto the top of the drawbar. You can hold the spindle from turning with the same hand that is inserting the collet or tool.
Ok that makes sense. Thank you.
I to dither about projects, should I do it this way, or, should I do it that way, to the point where I end up saying just do something then it's started.
Well I seem to have to dream and pontificate about a project for ever before anything happens, so I start that part of the process pretty early so the actual project might have a chance of materializing.
You guys are just like me. I swear I dither about projects for years before I finally get at them and then I wish I did them years earlier. Insert huuuuge sigh here.....
No way. A guy my size would collapse that thing and I'd knock over my BPort. Thankfully, I don't need one. If I did, I'd make a big one out of wood with outset legs so it would never flip on me. The only thing stools get used for in my shop is temporary workbenches to put tools and parts on.
Related question for you drawbar focussed guys:
Assuming that we are talking R8, how tight is tight enough?
I would think that its a function of the size/area of the tool engagement. A 3/4" tool needs more torque than a 1/4" tool. But maybe there is a standard that works for all.
I sometimes worry I'm too tight. I've seen what insufficient torque does.
I asked this same question in another thread but nobody volunteered an answer. It probably got overlooked or its a dumb question and I'm too dumb to know it.....
One more related question guys...
I've been thinking about that groove and how it got there....
I assume that both collet, cutting tool and spindle bore should be degreased and clean before use, but what is the recommended drawbar torque? I doubt it relates to the strength of the thread on the Drawbar. But I bet it does relate to the clamping force on the collet jaws.
I did a quick search on-line just now. I've seen everything from a quick shove on a 10" wrench to your eyes need to pop out of their sockets and a few attempts at relating air powered drawbar tools to torque. But nothing that I would call solid advice.
Anybody here have info like that?
I wished for a PDB for years - reaching up there for manual tooling changes just wore me down. Finally built a simple one using a Princess Auto Butterfly wrench. It was a great improvement - with one caveat : watch your air pressure and think twice before making any heavy cuts. In the last 6 months since I built mine, I've had 2 incidents where an endmill pulled itself down in the collet. My air compressor is a bit on the noisy side and I don't always turn it on. If your air pressure has "sagged a bit" and you step into a heavier cut, you may be at risk of an end mill slipping down. I saw a comment a few days ago saying that PA has a heavy duty butterfly - I probably got the weaker one. Gonna turn my air pressure regulator up a bit when I go out there today.;)
You know what they say about dumb questions...no such thing as a dumb question only dumb answers. I too have been wondering about the correct amount of torque on the drawbar.
I have found out the hard way what too little torque does but I really don't have a clue what enough or too much really is. The cheap butterfly impact wrench I bought has maximum torque of 75lbs. I relate that to how much torque I put into tightening wheel lug nuts on my minivan, (recommended about 75-80lbs. I would think that sort of torque on my draw bar would be certainly adequate but not excessive. I considered the higher end impact wrench that delivered 180 lbs but was worried it would be too easy to over torque the drawbar with that. Now I don't know if the cheap impact wrench will actually deliver that sort of torque easily and consistently or only with oiled threads, 120 psi and on a sunny day. I guess I should test that.
I referred to this article in my thread on the CNC conversion.
Posting with link to Rick Sparber's WUT
I find that for normal wrench based draw bar work that I don't need a spindle lock.
The impact wrench when just used by hand on my mill without using the second wrench for the WUT doesn't really turn the spindle. But now that I have an AC servo I'm finding it acts as a brake and prevents the spindle from turning.
However, depending on how your upper drive section is configured, if you use pneumatics to bring the impact wrench down then as it goes down it could push a spring loaded pin that would drop into a hole in the pulley if the spindle did make one turn. Or put in 3 or 4 holes to keep things balanced.
Doesn't even have to be pneumatics. If you have a lever you pull down to engage the socket that then closes a switch to enable an electric impact wrench you could have that also push a pin into the pulley. That leaves one and on the lever, perhaps even twisted clockwise or counter clockwise to load or unload the draw bar. The other hand to hold onto the tool or catch it.
