CX605 Down Feed Tune Up
In April I had a plastic spindle drive gear disintegrate. Member Brian H bailed me out by sending me his spare (Thanks Brian). Shortly after the gear failed I ordered two more gears (backups) from BB. Come July BB still hadn't supplied my spare gears:-( I gave up and ordered the LMS belt drive and air spring upgrade kit.
At $300 landed it's a pricy upgrade for a $900 mill. Worth it?
Boy, I'm impressed. The belt drive was well put together and installed without a problem. The mill runs a LOT smoother with less noise and the air spring really changes how the down feed behaves. Spindle travel increased from 7" to 10".
The kit arrived within a week. Installation took maybe 4 hours at most (I picked at it after work drilling and tapping one hole at a time in the evenings).
What has resurfaced is an excessive amount of backlash in the down feed. Once taken up the analog dial does match my DRO, so that's good. I didn't shim the new Z-axis rack when I installed as I didn't have any shim stock long enough to accommodate the longer rack (a future project).
If you have a mini-mill this upgrade is well worth it IMHO.
LMS includes a laminated RPM chart to mount under the RPM/OFF/ON switch. It calibrated well with my $12 tachometer.
Bofobo
M,Mizera(BOFOBO)
I dont have long shims in mine only 3 1” pieces. I tried my new treadmill motor conversion today and made .03 cuts like it was nothing. But following your advise on the gib screw for headstock adjustment i found i am missing the nut, and i need to enlarge the relief hole in my dro mounting to replace it o_O
Johnwa
In April I had a plastic spindle drive gear disintegrate. I didn't shim the new Z-axis rack when I installed as I didn't have any shim stock long enough to accommodate the longer rack (a future project).
What size of shimstock do you need?
I have a couple of rolls 6”x100”. I don’t recall the thickness.
Cheers
John
Cheers
John
Thanks for the offer John,
I need 0.02" X 3/4" X 13.5" or there abouts. 0.02" worked well with the original rack, the new rack may need something different. I need to play around with it first.
Johnwa
My shim stock is 0.001” and 0.002”. Probably not the easiest way to get 0.02” but you’re welcome to a section if you want.
John
That blurb is here..
http://www.machinistblog.com/the-mini-mill-head-drop-problem/
It may simply be one of those "don't believe everything you read on the internet" situations. Dunno.
More on z-axis backlash here.
http://www.machinistblog.com/an-easy-way-to-reduce-the-mini-mills-z-axis-backlash/
Another thing suggested is to slot the screw holes on the fine feed worm gear mounting block as a means of improving the mesh between the fine feed worm gear and the down feed shaft.
I don't think I'll attempt that mod, I'm pretty happy with the improvement gained so far.
Good info thanks for the links, I have a metal rolling mill so can roll copper sheet and try that.
