CX601 CNC conversion kit
lxs123
New Member
Has anyone done a CNC Conversion to Craftex CX601? Are there any off the shelf conversion kits available, i.e. ball screws, stepper mounting hardware, drivers etc.?
Ballscrews are not very expensive, IIRC I paid about $100 each for double anti-backlash. You can make the brackets and nut mounts for about $100 of material. I have now done two roll-your-own CNC conversions and both were quite easy. It does take time though so that needs to be taken into consideration.
I also have a CX601 mill and have been (very slowly) converting it to CNC. I did succeed in converting it but there was some slop in the Z axis and ended up mothballing the project (for years) and am coming around to try to solve that issue. I ordered the ball screws direct from china. Power supply, steppers, drivers, and other electronics from US suppliers (some components like bearings were ordered from motioncanda dot com. The rest I made either on the mill itself or my lathe.
The conversion kits linked by gerritv, david_r8 look pretty nice. And honestly, unless you really like having to solve problems these might be a great way to go. On the flip side, I learned a ton about bearing loading, ball screws, thread pitch & torque, different screw support configurations and their impact on accuracy, rigidity. Hours sunk reading books (Mechanical Engineering Design & Machinery Handbook were helpful) Even spent some time with a NTN bearing engineer on the phone discussing matching bearing configurations, pros & cons.. and the list goes on. It was and still is a rewarding process.
The rabbit hole is pretty deep depending on what you want to do and what you want to get out of it.
were any on the cx 601?
do you by chance have a list of parts you used? thanks
No, the first one was a BB LC-30 round column mill and the second one is a BB A1S 8x30 knee mill.
When I did the LC-30 it was more out of necessity because I couldn't find a kit. When I started looking at kits and installation videos for those kits for somewhat similar mills, it became obvious I would be paying about $1k for motor mount brackets that I could simply make on my mill. Everything else is just generic stuff easily available from eBay, Amazon etc. Second time around I just built on what I learned first time around.
This time I decided to use ac servos instead of steppers, although trickier to setup they are near silent and more powerful for a given size in comparison to steppers. First mill I used a cogged belt between the stepper and leadscrew, on the new mill I just coupled the servo shaft directly to the ballscrew, much simpler. I still have to implement the Z axis on the new mill but I'm just thrilled with it already.
I made a lot of chips on the 8x30 yesterday and I was grinning the whole time;-)
My buddy has two PM square column mills (looks bigger than a CX601?) and he is converting one to CNC at this time, if you have specific questions I could ask. These style mills seem really popular so it should be easy to find installation pictures and videos showing how people have done it. Suggest you start with whatever axis is simplest when you have that working you will be more than motivated to figure out the others. If something isn't perfect you can always tweak it. A couple of motivational pictures.
https://einfach-cnc.de/umbau-fraesmaschinen/ provides free drawings for BF20 mills, e.g. G0704 and KC20VS. You could get inspiration from the approach. It uses belt drive and ball screws for a compact conversion. I agree with @slow-poke that rolling your own is much more affordable.
Use the auto-translate feature in Edge or Chrome in case you don't read German.
Great link!!
I just grabbed a used KC20 off FB marketplace for $700; owner thought the bed had seized up, wanted it gone. Turns out the gibb adjustment screws were loose, and the gibbs were jammed in the X & Y axis. He said his kid messed it up, I figured he just didn't read the manual.
Stripped down, you can see the #49 stampings from the casting factory, same as PM, and all gibbs & ways are very nicely hand scraped, lead screws have nicely machined & adjustable blocks, everything is quite tight. Some surface rust on the bed & non-contacting points of ways where moisture got in, but otherwise identical to PM 25's & Optimum BF20.
Anyhoo, I'm going to rebuild it as a winter project with the einfach conversion plans, add a brushless drive with belts, and try my hand at a linux system.
Great link!!
Do you have a link to the Einfach conversion plans?
