Megar arc 5040dd
What is everyones cutting oil/fluid of choice for the home shop? Do you have different ones or a one size fits all for all your needs. I am at the end of the bottle and thought I would look at what is out there and maybe try something new. I have been using this https://www.homedepot.ca/product/masters-cutting-oil-500ml-spray-bottle/1000723450 for the last 10 or 12 years at least. I use it for steel on the lathe, mill, drill press, and for tapping. I would just pick up a bottle from home depot every few years but last time they no longer carried it in 1L bottles. it works good but it smokes more than I would like especially in the winter when I don't want the window open and the fan going. I have found it online at home hardware so I can still get it locally if I decide to go with it still. for aluminum I use WD-40. I know this has probably been asked before but I am really bad with the search function on this site.
Also wondering how much you guys use and how you are applying it on the lathe and mill? I am starting to think I am using it a little to liberally but not sure how to apply less. I am just bushing some on the work with an acid brush but usually end up with an oily mess on the machine when I am done a part. Or is it normal to have a fair bit on the surface of the part? do you reapply between each cut or less often?
