You’re welcome!! Glad I could be some help.
Good to hear you got it home safely!
You mean a Gits cup oiler or similar? I've been all over the mill and I don't see anything like that. If I look up under the table, I can see the screw and nut so it wouldn't be hard to get some oil on those.You can oil the bottom of the table with way oil. In bigger mills there is lubrication reservoir and I put in sae 30 non detergent oil in it so it goes nice through little tubes.
Spindle probably has an oilier cup - use same as for drill press column... after all you have a ... drill press. Its to lubricate the movement of the spindle housing when drilling holes. There may be additional cups for bearings.
for column you can use heavier oil so it sticks.
Albeit 700 pounds of 'drill press'! 😀after all you have a ... drill press
The ad is still up and given the mountain of stuff, I expect he'll be selling for some time:Hey Craig,
Do you know if the Orilla guy is still selling things? I am only 15 minutes from there.
Your fast feed button might be gummed up and stuck. It should click on and release when you let it go.
https://www.kijiji.ca/v-hand-tool/h...ss/1450321703?enableSearchNavigationFlag=trueSo I've made some progress on my mill in the last week. As I mentioned above, the mill did not come with a vise. Back in April, I had bought a vise through an online auction that was in pretty tough shape:
At the time, I couldn't get the movable jaw removed and therefore couldn't get the base off. The locking collar (left end, above) would not move. I decided I had little to lose and applied some brute force whereupon everything came apart easily! After some clean up and using my mill to make some soft aluminum jaws, it now looks like:
Still need a proper handle and a non-marring set screw for the collar. And it is a bit of a weird vise. It is 4 inches wide but the jaws are not quite an inch high. I will get something better at some point.
I also got some collets and other bits for the machine. A fellow (way up in Orillia) was selling a lot of stuff. He'd already sold the machines but still had two garages piled high with all sorts of machinist stuff. To keep the peace at home, I had to say "No" to an awful lot of tempting stuff!
Also, I got the needed replacement parts for the X axis of the DRO. Shooting Star Technologies shipped me the scale promptly. Not sure how the previous owner had made it work. I had to futz around a lot to get the scale and head properly aligned, including elongating some holes in a mounting bracket and making my own stand-offs for the scale. Sorry, it was done after I took the above picture.
BTW, the Z axis DRO isn't perfect. If I feed downward and lock the quill, the DRO will jump 5-10 thous when I turn on the power. I think the head is binding and then is released by the vibration when running. This only seems to happen when feeding down. The position readout doesn't change if I'm adjusting the quill upwards.
Also on the hit parade is the power feed. It works...but just at max speed. I'm hoping the Rapid Switch is just stuck. Does anyone have an Align power feed? I don't feel any action when I press on the rapid switch.
Thanks, I know John. He organizes the Tools of the Trades antique tool shows twice a year.https://www.kijiji.ca/v-hand-tool/h...ss/1450321703?enableSearchNavigationFlag=true
I’m not sure if you saw that ad yet
Believe that's part of the DRO.
I got the replacement part and I've remounted it on the front of the table. I think I'd have to disassemble a lot of the X-Y carriage to be able to drill mounting holes on the back. Plus the read head has to protrude past the scale a bit which could put it at risk of being squashed against the column if I moved the table all the way in....It would be better to re-mount it on the back of the table so you don't drop some heavy part on it.
I’ve seen some guys put a piece of angle in to protect it from above.I got the replacement part and I've remounted it on the front of the table. I think I'd have to disassemble a lot of the X-Y carriage to be able to drill mounting holes on the back. Plus the read head has to protrude past the scale a bit which could put it at risk of being squashed against the column if I moved the table all the way in.
I may well do something like that. I'm thinking now that I may have to remount the Z axis scale.I’ve seen some guys put a piece of angle in to protect it from above.
