lucsimoneau
Goodday to all ... hoping to validate my next move before destroying my control board, lol!
OK, so the CX601 comes with a variable speed DC motor controlled by a potentiometer. The control board is a KBIC IC-AAC, here's a picture:
I'm in the process of wiring this up to my converted CNC machine with the Centroid Acorn controller and I want to replace the potentiometer with voltage coming from the Acorn board.
From what I've read, the P1, P2 and P3 lines coming from the potentiometer need to be replaced by voltage to the P2+ and F- connectors on the KBIC board.
It is recommended to install a signal isolator KBSI-240D from Acorn to the KBIC for signal isolation.
I've tested output voltage from the Acorn and it's in line with maximum spindle speed setup in parameters (0-10V). The KBIC documentation states that the voltage must be set between 0 - 7V, which is easily accomplished with the KBSI-240D isolator board.
So here's the question:
The P3 line (blue) is only between the control board and the potentiometer, so just need to disconnect.
The P2 line (brown) is connected to the potentiometer and also to the magnetic switch, do I disconnect from both and connect the (+) voltage from the KBSI-240D?
The P1 line (black) is connect to the potentiometer and to the filter, do I just disconnect both these lines?
Any help would be appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
![Capture1.JPG Capture1.JPG](/data/attachments/38/38331-32d276baaae459fb4faf26faa784eb71.jpg)
![Capture2.JPG Capture2.JPG](/data/attachments/38/38332-ea16103c02ddf69d776625dd2b350477.jpg)
Thanks!
