Craftex CX601 DRO instal
thriller007
Thought it might be a good idea to post some pictures of the dro installation. First we are starting with the x axis. Ordered a 600mm travel but could have went with a 650. Have enough travel on the 600 but 650 would have been slightly easier.
DRO unit installation and Z axis installation. Again the Z axis was a 450mm but could have fit a 600mm on there with no issues.
Lastly working on the y axis. Not finished yet but getting there.
Looks good are you going to put a fan on the motor casing because there is only 2 vents In the cover that’s not enough for cooling if your running for any length of time.
Sure am. I actually installed a power bar today so that I can power up that one you sent me, thanks very much. Also finished putting in the y axis this morning. Now just need to put some covers on the bottom two scales.
If your readers are below the scales you really don't have to worry about covers. Never hurts though.
Have a look at that mini. On the y-axis the reader is on the horizontal outside of the scale, not good, swarf trap. And as I recollect, the reader on the z-axis was facing the front of the mill, double not good, big swarf trap. The only scale that was mounted in a reasonable fashion was the x-axis.
Yes I set it up so the readers are below the scales for the x and y and for the z the reader is on the backside.
Looks very similar to my own setup. I only went with a two axis as I saw no use for the third. I do use the readout on the quill as well.
