CNC Hybrid with low hours
Alexander
20170930_172829.jpg this is the milling machine I converted to CNC. It has a built in coolant tank with a good coolant pump. Both the vertical and horizontal spindles have there own 2hp motors. Machine is very rigid, it has a head that tilts and a table that swivels. Everything runs on single phase. Machine it turn key ready to run. Comes with a stepper motor and driver for the z axis but I have only hooked up the the X &Y. Great for drilling and 2d milling as is. The only thing you would need to do to make it 3 axis is build a motor mount to attach the included stepper to the Quill. The Z axis stepper and driver are already wired in.
$3500 machine is located in Calgary
