Center drill or spot drill
I've recently started to notice more and more people using spot drills in the machining videos I watch on youtube. I don't know if they are becoming more commonly used or if they always have been and I just never noticed before. I have always just used a center drill to start my holes either on the lathe, drill press, or mill. I have found it always has worked well since center drills are very short and rigid. Is there an advantage to using spotting drills? Are they something I should be looking at getting? Or is it just a personal preference thing?
I use centre drills to drill for tailstock support on the lathe and use spot drills for, well spot drilling.
Spot drills are (or should be) short & rigid too. Most are carbide so even more rigid than HSS. The issue is the angle. Typically center drills are 60-deg included angle with a deeper pilot. This matches the cone angle of a dead/live center & pilot relief for the point itself. Old Tymey these were also used to start (spot) for drills to keep them from wandering on start. Which is better than no pre-drill at all, but still not optimal.
For proper starting, the spot angle must be equal to or slightly larger than drill angle. So a 120-deg spot is a nice match for a 118-deg jobber drill. More & more drills are produced with larger angles like 130-135, so technically the 120-deg spot is not quite right for those. Having said this, newer styles may also have split point or other geometry features that help them from walking vs the plain spiral relief of typical jobbers which have a proportionately large no-drill-dead-zone center core. I bought a few 140-deg spotters in small diameter to try & they work well on 135's (but are expensive). But as mentioned in another post, there are also these combination spot/chamfering tools form Asian suppliers, almost always carbide. I'm having trouble seeing the difference so for the low cost I'm going to try. Ask me in a week. Oops the CP strike...maybe longer
Spot drills are (or should be) short & rigid too. Most are carbide so even more rigid than HSS. The issue is the angle. Typically center drills are 60-deg included angle with a deeper pilot. This matches the cone angle of a dead/live center & pilot relief for the point itself. Old Tymey these were also used to start (spot) for drills to keep them from wandering on start. But its an established no-no. For proper starting the spot angle must be equal to or slightly larger than drill angle. So a 120-deg spot is a nice match for a 118-deg jobber drill. More & more drills are produced with larger angles like 130-135, so technically the 120-deg spot is not quite right for those. Having said this, newer styles may also have split point or other geometry features that help them from walking vs the plain spiral relief of typical jobbers which have a proportionately large no-drill-dead-zone center core. I bought a few 140-deg spotters in small diameter to try & they work well on 135's (but are expensive). But as mentioned in another post, there are also these combination spot/chamfering tools form Asian suppliers, almost always carbide. I'm having trouble seeing the difference so for the low cost I'm going to try. Ask me in a week. Oops the CP strike...maybe longer
Book marked for future reference.
You can imitate spot drill with center drill by using only the tip. For carbide drills you should always use spot drill or similar imitation as the angles need to match or your carbide drill may shatter.
For HSS it does not seem to matter as much - I think main issue may be accuracy - spot drills may guide HSS more accurately. But the difference is small. Center drills are far cheaper so the get most use even through they are not the right tool for the job.
Also my edge finder is 1/2 and a center drill common size is 1/2 so switching them in a collet is very fast.
I used to center drill only. I have switched almost totally to spot drilling first. Even a center drill can sometimes wander a bit. Believe it or not, I even use a small spot drill start before using a center drill now. Maybe that's overkill, but I've been bitten once too often. I'd rather be certain of the outcome than try to fix it later. I bought a nice set of spotting drills that make using collets or a drill chuck very easy. If I can find it, I'll add a link here later.
Lots of information out there but this Stefan video covers quite a bit in terms of spotting. Other good resources is sharpening drills even if you never do it, because it illustrates various tip geometry details.
Another misconception is drilling a pilot hole first will make an enlarging hole accurate. Not really. Removing a smaller diameter core of material does help with cutting forces in a few modes, but the same issue exists in terms of centering. The cutting action of drill #2 will see one of the sharp (now 90-deg) corners as first contact point & that action can adversely influence drill path as it starts to feed. Very different than a spotting drill mode where a cone divot helps a cone drill from wander. Now in all fairness a big drill is a big roughing operation not a finished or true size. But where tolerances come into play, or deep holes, or difficult materials or... giving the hole its best start helps you in the end.
Good summary Peter and a nice video. Even Gotteswinter wears me down though and I started fast forwarding.
Quick summary for others.
Center drill isn't a good spotting drill unless you only use the small starter end and don't drill a full center hole. The full hole is lousy..
Next best is a 90 degree spotting drill. But it's not great.
Best is a 120 degree spotting drill. But use one only a bit smaller than the drill bit you plan to use later.
If you have a tool grinder you can make your own D-Bits. I don't so I'm not gunna.
All the spotting drills I bought are 120, so I'm happy.
But the center hole isn't for starting drill bits? The second part of the profile is to make an angled hole that has relief at the center so that a tool (like a center) can then be engaged.
To start a hole for a drill bit, only a small portion of the first part of the profile should be used. Just enough to stabilize the point and prevent wandering until the drill itself becomes stabilized by the hole that it is cutting. And needed because the 'point' of a twist drill isn't a point - which is bad at the start of a hole, but very necessary as the whole becomes deeper
And I guess that a spot drill may be better, but as long as the 'dent' from the center is slightly larger than the drill 'point' I'm not sure that it will matter much. But maybe I'm all wrong
Well, we went down this rabbit hole when trying to find the best way to teach this subject to new students. To make things simple, our guidelines are: CENTER DRILL = LATHE CENTER (60 degrees), SPOT DRILL = CNC DRILLING with the added benefit of producing the 90 degree chamfer on most holes at the same time. We have since purchased multiple KAR and Nine9 Spot Drills (carbide inserts) that we use for spot drilling and chamfering. We also have Harvey Tool's carbide Chamfer tools with 90 degree point angles and a 0.010" flat. Works great for spotting and chamfering also. Just my 2%
My summary was just what Gotteswinter said in the video, followed by where I am myself on all this.
I took no apprenticeship training. Everything I know was learned by watching/listening to others. Especially the skilled trades wizards we had in our engineering prototyping lab. Those guys were the best of the best hand picked from machine shops and dealerships all across Canada. I have also learned a shit ton from the wizards here on the forum - but all tempered by my own science knowledge base.
I'll comment more below.
Because a good center drill has a 120 degree cutting point, it can be used as you described as long as the first straight section of the center drill does not enter the hole.
But I don't often use center drills that way any more. It's too easy to drill too much and get into the straight section.
I think you mean third. In my mind, the second section deepens the first and provides a clean hole for a lathe center. But yes.
Yup, that's the gist of it.
Fundamentally, I agree. But I have found 4 things that I think make a proper spotting drill better.
1. The flutes on some center drills and the double ended nature of many often makes holding them properly in the chuck difficult.
2. As noted earlier, it's often too easy to drill too deeply and engage the straight section above the small tip. Even a tiny slip is bad because then the angles are wrong for a proper drill start.
3. Some center drills have a flat point just like a drill. In that case, their only advantage over a plain drill is their additional stiffness.
4. The size of a proper spotting drill is more appropriate for starting a drill, the angles (assuming you buy the right ones) are perfect, and they are readily available in carbide. Center drills are available in carbide too, but much harder to find.
I have a nice selection of carbide spotting drills in both 90 and 120 degrees. I almost always use them and prefer them.
Almost always spot drills, or sometimes just the very end of a centre drill. For all the reasons mentioned, plus it's hard break the pip off of a spot drill. I think the use of the centre drill comes from it being a short rigid tool available in every shop, but the spot drill imo is preferred.
Let me throw something out there. I think the precision of the grind on a drill is more important than the angle of a spotting or centre drill.
With a typical 2-flute twist drill, if one flute is even slightly longer than the other, that flute is going to take a heavier cut and thus be pulled across the surface while starting and likely give you an oversize hole. Possibly result in a non-straight hole, too.
I've never understood why so many people believe freehand sharpening of drills is a skill everyone should have. Using a jig only takes a little longer and gives a much better chance of getting consistent geometry on both drill flutes. The only justification I can follow is if we consider drills to be strictly a roughing tool and accept that the results will often be different to some extent from the stated size. Isn't this a problem for tap drilling?
While I'm on my soap box, I think that split points/4-faucet points _only_ matter for production drilling. Otherwise, use a pilot hole the size of the web in the final drill.
Just to add to what @trlvn just wrote - drilling IS a roughing operation. The drill will almost always produce a hole that is bigger in size (from +0.003" to +0.006") and is not straight. Using a reamer is a better solution when trying to reach a certain diameter but best of all is going to be boring head/bar which will make the hole concentric and on size. To that extent, I've used burnishing tools to get parts with very tight tolerance holes done on production parts. So in summary: It all depends on what you are trying to acheive (haven't even started talking about GD&T yet :) )
I wouldn't necessarily say more but I agree it is very or equally important. You can test it with a known, very accurate drill point grind. Spot with the proper angle spot tool (angle & depth), move the table over 10 thou, enter the spot with the perfect drill. The tip will bend slightly towards the divot cone center (extent dictated by drill rigidity & many other factors). Anyways, how about a good spot plus a good drill is better than a bad either/or.
But what you have described is probably the root mechanism of why the 60-deg center drill isn't great. If one of the cutting edges is only 0.001 deeper, it will see the stock edge first. It will probably do some low grade chamfering around the perimeter until the second lip comes into the picture. (My exaggerated sketch. It would be neat to see this in slow-mo actual cutting conditions). If you have ever used non dubbed drills in grabby materials like bronze or brass, you know the power of how a cutting edge at high rake can self feed into itself, sometimes to the point of sucking the tool out of the chuck. Anyways, I don't think the world will explode by using 60-deg center drills. But if you need accuracy & consistency, use the tool that will help.
With my TCG slow progress I'm coming to the realization that a lot of commercial drills are sh*t. Even with everything jigged & fixtured, doing a faceted grind to the same depth stop, you can see differences on the point under magnification. Many drills are warped to the extent the cutting edge is different. Or the 2 flutes are not equal which results in a slightly different cutting edge angle.
:eek:Please don't share anymore. Ignorance is bliss. I want to just buy something, anything for once and just be happy that its as designed / expected, and not have to rework it.:(
Versus the alternatives (do nothing, or a center punch) both seem preferable. I think we can all agree that a spot drill is the best, a center drill used well is very good, a center drill used badly maybe okay, and the other options are much worse.
And if you need an actual precision hole, drilling it won't do it no matter what technique you use. The center will wander to some degree, and the relatively thin section of a twist drill (necessary for chip extraction) will wobble too
It seems unclear in my mind whether boring or reaming would be better, but it probably depends.
What's the next hornet nest I can kick over ;)
