Unfortunately, this is the force component that is broken, and I can try to clean the other piece, but that area is inside, and neither the drill nor the grinding blade can get closeCan you mill it out from below and use a new piece of steel in through the slot? It looks like alignment, not strength.
Are you sure cast iron can be argon-welded? How about welding and strength? Is brass electrode OK? I remember 6 years ago argon welding with copper electrode was very difficult, sparks were flying and failed ----Can't it be tig welded with silicon bronze rod? I am pretty sure that I remember you having a tig welder.....
Interesting offset design on that vise, I have not seen one like that before.
Yes I’ve done it before. The rod is designated ERCuSi-A. You will need get the part clean and pre heat the cast iron. Done correctly, only the rod will melt, the cast iron will get red hot but not form a puddle.Are you sure cast iron can be argon-welded? How about welding and strength? Is brass electrode OK? I remember 6 years ago argon welding with copper electrode was very difficult, sparks were flying and failed ----
If you don't have the equipment, and don't want to buy it to do this repair, take it to a shop and hire them to do it.They convinced me brazing was the way to go. They would not weld it, said too many potential problems and that brazing was just as strong. If you get a good joint that should be true given the tensile strength of the braze.
Anyway, everything I've read says brazing is as good, person experience says its as good and a firm that does nothing but CI repairs says its just as good. A couple years later the rolls are still rolling.
Yeah it’s brazing but just with a tig torch.Sounds like the chemistry/result is a lot like brazing? I mean the parent material is not fused but bonded to bronze. At home I've fixed small CI breaks with braze and its worked well. But easy to have that sort of intuitive prejudice that it just can't be as good as melting the parent materials together.
That bias is unwarranted. A story that sealed the deal for me. Some meathead put far too thick and wide a plate through our roller and busted the main headstock casting. Despite have lots of great welders, our guys having limited to no CI experience, and it was a production machine, so I hired a specialist firm to fix it. These guys are hundreds per hour and travel all over doing cast iron repairs; its all the do.
There’s another cast iron repair method I’ve seen before that apparently works quite well. It uses inserts across the crack that are pressed in, peened and ground flush.
Right, It is very porous, so the bronze mixture ( copper zinc and tin ) bonds well to the CI. The reason I said to skip the TIG method is the fact that old CI that has been in service a wile will tend to be oil soaked and or dirty and will need to be heated and or cleaned well. Several times infact, If the oil keeps seeping out.Sounds like the chemistry/result is a lot like brazing? I mean the parent material is not fused but bonded to bronze.
I forgot to tell you the progress of the vice repair, I carefully checked the broken part, it is supportive, but if you do not use a very large clamping force can ignore it, and I never have too much expectations of cast iron force, so I decided to do no repair, continue with the status quo.Offset bench vise are handy to have in the shop and they are not cheap. Well worth to have it repaired. I hope you find a good solution or someone with experience welding to fix your vise.
The other day I dropped my small drill press vise and it broke in half. I had some ERCuSi mig wire (Blue Demon brand) and some argon gas so I decided to give it a try. It was my first time using this wire and I was looking forward to give it a try. I did a good bevel around the cracked edge. The wire is only .024" dia and I was trying to weld some 1/4" cross section, so the setting on my mig welder were all max out. It didn't flow so well on the first pass, but on the second pass it seemed to have enough heat to flow nicely across the two sections. I then proceeded to grind all the excess weld, it looked ok, no large pores and a decent fillet, but a lot of black soot around the weld. Oil burn off??? I clamped a pipe in the vise and it seemed ok, until I squeezed it a tad more. LOL it broke in half. With a cold chisel I was able to chip the weld off the cast iron clean, like mentioned its more like a glue, no fusion between the metals. If I ever get the urge to try to fix it again I would do has suggested, a good oil burn off with a torch, sand blast the crack and a pre heat before welding. And I would not use my mig with that small wire to weld a 1/4" cross section, I would instead try to braze it together. I do have a small bench vise which was torched brazed 20 years ago and it's still holding together. Maybe because it was done by a professional.![]()
