Can you drill a magnet?
6.5 Fan
I thought this subject was discussed already but can't find it. Maybe i was dreaming, so can you drill a hole in a ceramic magnet? I got a couple of cheap ones from PA and had a thought about some uses but need to attach them to wood. Glue might work but they will be outdoors so a stove bolt thru the middle would be the simplest solution. I could do a test i guess also, 5 bucks for 2 magnets is not going to break the bank if one shatters.
You may be able to drill with a small diamond spade bit for drilling ceramic tile. Chances are the magnet will crack through.
Clearly you need $20K water jet to drill these $2.5 magnets. :cool: Those magnets with hooks on them I think have a hole through - also inexpensive at PA.Please post if you can successfully drill.
I've used silicone for "glue" several times -- to glue house numbers onto a big rock outside our house -- 23 years and they're still there.
If there's some "stress" on them a more upscale silicone might be required -- "The right stuff" sticks like cat poo to a blanket.
Would something like that work?
JB Weld works well, and Lepage PL600 landscape adhesive or regular PL polyurethane adhesive work great. Only snag is the PL adhesive takes a long time to cure.
It is a ceramic magnet, so is a china plate. Practice drilling a plate first.:p
I would use a cheep PA hole saw about 3/8 OD to do it.
I have drilled ceramic tile using cheap, hardware store quality carbide cement drills - no problem.
When drilling into hard brittle material, support is critical. You can get it by drilling a small hole far from the edge, or by adding confinement. In the same way that wrapping wood in cord or leather keeps it from splitting along the grain, some sort of clamping can make a big difference when drilling. It has to be tight and all the way around, so I'm not sure what to use for something so small. Maybe a cinch band
Maybe a hose clamp cold work.
They are quite inexpensive but the magnetic strength varies. I had one in a study lamp that could barely keep it upright never mind at an angle. Probably cost you more to buy the right drill. I have some cheapo diamond encrusted annular (core) drills & they were very slow going in a 1/4" thick grinding wheel. I cant imagine the magnet would be smooth sailing.
Maybe another option is buy some 1/2" diameter (or whatever) neodymium's which are spit cheap & just arrange them in a radial pattern on a washer plate. Grout them in place with epoxy. I bet it would equate to the same result if not stronger.
Just buy them already round and already drilled. They are dirt cheap. They are even countersink to hide the screw or bolt head.
Drilling is a no go. Tried several types of drills but nothing. Just to hard, so i guess it's glue time. :)
Just buy them with the holes already there. They are cheap. See post #5 above. Next day delivery. Well..... maybe next week where you are......
