Calculate proper radius for scalloping with boring head
Gennady
Hello team. How would you calculate/adjust radius on boring head for cleaning up this scallop (or half moon or crescend) ? I created initial rough shape with grinder, now need to make it conforming to the corresponding part. It would be welded on - so no extreme precision is needed, but still some level of accuracy is desirable.
If you have a compass you could make a template by drawing and cutting out a circle whose radius matches the radius of the part you need to match.
Then I'd copy that radius onto the stock, put it on your mill and roughly center the boring head over what would be the center of the circle. Then adjust the sweep of the boring bar until it roughly matches the radius you need.
I've been able to closely match radii this way.
You ask about setting the boring head so what I'd do is put a piece of stock vertically in your mill vise. Edge find one side. Mount your boring head and move the table away from zeroed edge by the desired radius and adjust the boring head to just touch off on the zeroed edge.
For a less precise , non boring head weld prep I'd just butt the crescent against the bar and run a soap stone or Sharpie around the bar. Grind off the mark, rinse and repeat as necessary.
is this just for practice with the boring head ? you could make a nice radius with the grinder in less time that it will take you to set up the boring head, nice enough to weld at least
Well. It is indeed practice with practical goal. I was thinking about some sort of sharp tip scribble mounted in the mill boring head (make sure it has the same outreach as cutter) , lower it to the alum plate make drag it over to make marks and adjust radius. Then change it to real cutter.
i cant imagine your close enough to go in with one pass anyhow, i would adjust your cutter so that it is just cutting, take your first pass, measure, then use the micrometer on the boring head to inch it out
