Brown and Sharpe 612 surface grinder
On my last trip to Vancouver this followed me home in the bed of my truck...
The first picture is in the shop where I bought it, and the second is packaged for travel.
- It is now disassembled for cleaning of the lube system and checking everything before starting it up...
That is a shinny machine .... A little to clean for all the metal dust it should have produced over it's lifetime but I do notice a nice big vent in pic one ... Solid idea to wear a respirator when using these, I mean black boogies are cool hahaha
I get them black boogies all the time when angle grinding...
There's a huge buildup of metal in the irrigation canals - they must have used coolant for all grinding, methinks, hence the clean appearance.
Great score!
That machine has not seen a lot of use, judging by the paint.
Is that the fully hydraulic version with the pump/resevoir in the base and an external coolant pump/tank?
It came with a 3 phase pump, coolant tank and all the coolant accessories. I prefer dry grinding - less mess.
It is, however lubricated by using the table hand wheel, activating a tiny piston pump. All movement is manual.
The downside (Must there always be a downside?) is that the lube system didn't work for years, and all the oil has turned to a thick goo, like a soft gummy bear. I've rebuilt the intake, pump and filter - I'm in the process of tearing out all the capillaries, the oiling lines and the manifold to get some lube on the ways and lead screws.
I'm too cheap to buy a machine that is in a ready to run state!
BTW It saw almost daily use for over 15 years, then left sit for almost 5.
