Tobho Mott
A friend and former co-worker (He taught leather work for a while where I taught sand casting for a while) has been waiting a long time for me to cast his sword parts. Of course, I've been waiting almost exactly as long for him to send me the dimensions for his patterns...
He came by on Sunday to see them cast in aluminum bronze. Which I call Valyrian bronze (a fictional anachronism) when i use it to make anything pointy. Mostly C954, but topped up with some of my homebrew Cu90 Al10. It ought to hold up better than tin bronze or silicon bronze if he ever finds himself in a real melee.
Probably my least favourite alloy to cast, it foams up with the slightest turbulence, not to mention shrinks like crazy. So I used a few extra tricks (surge traps on carefully sized runners and mold manipulation - slight tilting) to mitigate these drawbacks and Look Ma, no unsightly scabs of foamy dross! 🙂
I'm fairly pleased with these results, especially the crossguard. The pommel is OK too but just a featureless round disc that will get a lot of belt sander time before it's done, so it doesn't need to be as pretty as-cast.
It (Al-bronze) also work hardens like crazy which doesn't make it fun to work with. Cutting and filing the parts to fit the sword handle is his department though, not mine. I did warn him.
Told him silicon bronze casts nicer and works nicer and patinates nicer and is still a decent material for a crossguard, but he wanted Valyrian bronze so that's what he gets.
At the last minute he changed his mind about the diameter of the pommel and how he wanted to attach its halves to the tang, so I cut and sanded it smaller, added a central drill guide dimple to the wooden pattern so he could easily drill to pin the halves together right through the tang, and redid the shape of the slot in the mating faces which originally had passed right through the oversized version of the pommel.
Normally I'd prefer to have the patterns finished before I start making the molds. But I was glad I was able to adapt and get his parts made while he waited regardless.
Thank goodness for nails - the glue.for the adjusted pommel slot sides didn't harden in the time it took me to ram up the crossguard...
Jeff
Jeff
