• [Ad-Free Experience]
    Click Here to Register
  • We are working on a problem where password reset email and likely also new registration email is not arriving and people are having trouble logging in - we're working on it. Sorry about the issues. EDIT -> Josh thinks it's fixed. Contact us on facebook if you are stuck. EDIT-> maybe it's not fixed...hang in there we are working it.
Broken brazed carbide tooling
gmihovics
Garrett
I was given a ton of old broken brazed carbide tooling, is there anything I can do with them? do they have a use other than brazing some new carbide bits to them? will they hold a cutting edge if I grind them into cutting tools?
terry_g
I have ground brazed carbide tooling for years with good results.
Having the correct grinding wheel helps.
gmihovics
Garrett
I realise now I might need to clarify, when I say broken, I mean they have no carbide left, the piece was broken off completely.
@terry_g, does that change your answer? if not, how well does the tool hold an edge?
The shanks are soft and won't work as a tool bit. Take a file or hacksaw to one and you will see what I mean.
gmihovics
Garrett
This is what I thought but a bunch of these are ground into odd shapes so I thought maybe they were harder than I assumed.
Sometimes they have rather precise shank diameters. If so, you could make pins out of them. Perhaps even rough gauge pins.
trlvn
It is possible that the previous owner ground the carbide into some specific shape which then left the shank in a weird shape when the carbide finally gave up the ghost. I have a few pieces in that condition.
gmihovics
Garrett
ok thanks for all the info. I'm going to keep some of the bigger broken pieces as pins or material to cut on the lather and mill.
Degen
Grinding and sharpening carbide....diamond wheels really is the only way to go. Stone wheels in a pinch may work but once you've tried a diamond wheel no going back.
