Bristol Model 0 Small Vintage Knee mill, Modernized - Medicine Hat AB
Kelly McLaughlin
Hi Folks! It looks like I'm going to lose my extra work space come spring so I'm posting this now to see what if any interest there is. I hate to part with it but I just won't have space and it seems two mills is one too many : )
It started life around 1919 as a Horizontal machine. I did a tool refurb post on this site so if you hunt you can see what I started with. This little mill is kind of unique in that originally the table was run by a rack as wasas a 4" Z adjustment. At some point it was converted to a vertical head (Halco) that had a B & S 7 taper arbor and a 1/3 hp motor. I converted it to DC and 800 watts with a tooth belt drive and drove the spindle 1:2 to give 2500 at the spindle with infinite control on the Brass knurled knob(just halve the readout), The red knob is E Stop. The DC unit has reverse available, a bit clunky but once you've done it a few times it's quite quick. I also converted the spindle to R8 using a Bridgeport clone spindle and proper precision spindle bearings replacing the tapered rollers it was built with. It has power x with about 10" of travel ( there's another 3 ish available with a small modification but I was worried about table overhang) and manual y with 4" of travel, the total Z is around 14" between the knee and the Z rack there is also 4" of quill travel on a worm gear setup (very nice for drilling). There is DRO on all axis, x,y,z on the big DRO readout. The Quill has a stand alone. I also added a gearbox to the head to make rotation more controlable. It has approx a useable 45 degrees in both directions but cabling will inhibit the travel in one direction. The stand gets it to a comfortable working height and has levellers on all feet. As you can see there's a ton of hours in it that resulted in a really versatile small mill,( the foot print is 36" x 36") hence my reluctance. If you're interested contact me we'll talk and see what shakes out.
