So ive had this generator for quite a few years, but it has minimal hours, maybe 30 or 40. I went to go use it 2 or 3 months ago, and no luck, just pulls and pulls, no puffs, nothing, Ok, bad gas, replace the gas, still nothing, try ether, nothing, replace the plug, nothing, check for spark, it has good spark, ok, fuel directly in the cylinder, i get the odd puff, maybe i flooded it, clean the carb, still nothing. Played with it for a few hours and eventually put it in the shed. Here comes today, rainy, windy, might as well try for the hail mary, ill check the valve clearances, who knows, i have nothing to loose....welll
Broken rocker arm! what the heck? the first attempt to weld it broke immediately on the first pull, hmm. Valve is stuck? its been sitting inside the whole time its been stored, what the heck....what to do....well eventually i figured what the heck do i have to loose, love tapped the valve free, back and forth a few times to get it running again. welded up the rocker arm again, assemble it...drop the rocker arm pivot pin into the depths of the generator.....
tear it apart, reinstall, fires right up! but i dont really trust that will survive any length of time , so i re-enforced the arm with some flat bar, hopefully itll continue to work a long while now
anyways, a little ghetto, but i cant find a source for the rocker arm, and i dont really want to spend money on a new to me one, so there she is, things you can do with a welder
