Perhaps I can clear the backlash thing up. Craig was disappointed by the backlash in his BB head.
There are a bunch of causes for backlash, but the primary one is incorrect use. (I wouldn't dismiss manufacturing error as another likely cause).
-- I was taught to snug the 3 Veeway screws after making an adjustment, loosen them to make another, then retighten. An error all to easy to make is to leave too much pressure on the screws, resulting in excessive lead screw wear or damage. Note i said SNUG. it is a feather touch on the allen key, not a wrenching pressure. The load on the single point tool is very light: 20 kilos or less. You should never take large cuts with a boring head. It is not designed for deep cuts in heavy materials. My average cut in soft steel: 5 thousanths. In soft brass maybe up to 10 thou.
My lead screw has about ?5 thou of backlash, but since I'm always moving the head in one direction, I've never noticed it. My other boring bar has about 3 thou backlash. Same scenario.
An autofeed boring head has a completely different mechanism, and should not be fiddled with... you dial it in, and cut.
