calgaryguy
Chris
I've got a cast iron 'platen' from a large belt sander with a .030 worn side-to-side 'dip' in it. Nominal thickness of the casting is about .250 across the wide platen surface.
Similar to the low-looking spot in this pic
The face with the bolt holes facing the camera is ground at a 90deg angle to the large platen surface. I assume someone would have to use this surface to clamping as the unseen edge away from the camera has no edge.
I am, of course, looking to have this done cheaply. I've been told about, and read about 'blanchard grinding' like is used for resurfacing flywheels. etc.
Anyone in the forum know a place in Calgary that might do something like this for a reasonable price? REasonable being $50 or under - similar to a flywheel grind/resurface.
My other option is to attempt to do this with a friends mill/drill and a cutter.
Some people online have 'fixed' this with JB weld and then sand it smooth after, but the repair doesnt hold up very well from what I've read
