Best tool/method for cutting v-grooves with milling machine?
kevin.decelles
I want to machine a replacement riser for a head/tail stock for an old lathe. This will involve cutting a v-groove and I am interested in the approach everyone would/has used and would recommend.
I've watched some videos, Tubalcain goes all end-mill w/head rotate, others use a double-angle cutter, some use magic and machines I can't afford.
The double-angle cutter is interesting to me, but I don't want to plunk down money if y'all say it is a waste, or if there is a cheap easy way to do this with standard tooling.
This is a smaller lathe, and the v-grooves are not that tall (think 1/4") high. If I had socks on I'd run out and measure the angle, but assume 'typical'
Johnwa
#2
Kevin
I have my socks on so I checked my Southbend’s way. The top angle is 90 degrees.
When I made a carriage stop I mounted the stock at 45 deg and cut the groove with an endmill.
John
