Ben lathe bed
Something confuses me,
The lathe bed rises about 0.020" as you get closer to the head stock but your last picture shows a tail stock about 0.050" low?
I would be tempted to pull off the head stock and other items and put a straight edge across the whole bed and check with feeler gauges to see what the dipitty do da* really is. Maybe the head stock is shimmed up for some reason? Not sitting on the ways properly? Maybe there are leveling screws that are out of adjustment? Is the head stock parallel to the bed (as in it is pointing straight and not off into space?
*Note: Dipitty do da is a highly technical term that can also be used in singing children's songs by substituting a letter Z for the leading D
The headstock actually sits directly on the ways. There is no adjustment in any direction.
I hadn't set the dial indicator, it was just to illustrate how I had it mounted.
Using the carriage or tailstock to measure for wear on the bed is possibly confusing the issue(s). If the wear is localized, both the carriage and tailstocks could be 'pitching forward' when they enter the worn section. Etc.
Why not use a straight edge to directly check the straightness of the bed [1]? Given the big misalignment between the centers, I would guess that deviations should be easy to see.
BTW, do you know anything about the history of the machine? If it was used in a production environment doing the same operation repeatedly, virtually all the wear could be localized to a pretty small section of the bed.
I think wear just seems to be a more likely answer rather than the bed being bent. The link Tom Kitta supplied suggests that the ways were made of hardened steel. It is hard to imagine them sagging--especially to the magnitude shown. Unless, of course, some previous user was slamming down 1,000 pound loads directly onto the bed?!?
[1] Lee Valley has an inexpensive line of straightedges that would be accurate enough for this job:
https://www.leevalley.com/en-ca/sho...d-measuring/56676-veritas-steel-straightedges
Although it isn't the quality of the straight edges you so kindly shared a link for, I put my 4' level and used feeler gauges and found my largest gap to be about .009" in the area I measured.
