Belt Sander Electrocution
thestelster
I keep getting electrocuted when grinding down metal on my belt sander. How do I stop that? It arcs from the metal being sanded down, to the belt guard, and then through me. It also happens when I flip the switch to turn off the machine. I've started to use a stick to turn it off, but don't know how to prevent the other.
Still the same. And then I tried putting the alligator clip on the actual switch toggle, and the shock was even worse.
Ok, I looked in the switch enclosure. Everything looks good, nothing loose or burnt, everything is tight and I checked the continuity of the ground of the plug to the switch, and it's good there. Now what? Go into the capacitor box?
I don't know if metallic dust in & around the motor windings can manifest into static or shocks, but might be a good idea to have a peek in there too. Vacuum out or blow it clean. The good thing is, looks like your fan is on the opposite side but check cooling direction & any intake openings. I once made an edge chamfering assembly using a trimmer router but I started to notice some little electrical storms & realized it was possible for metallic swarf to drop in there. Normally the motor is pointing down not up & pushing air out. Sawdust buildup could be troublesome but its not problematically conductive. But it sounds more like a connection or component type issue if I had to guess
Well, I vacuumed everything and was still getting shocked so I grounded myself to the belt sander. Worked perfect, though the alligator clip bites a little hard on my finger (hence the elastics to counter act the forces). Amazon sells an anti-static wrist band for $10.00 which I'll order.
