Breakdown maintenance is the most expensive type of a maintenance program. I was dealing in part with 18000lb gearboxes driven by 1000hp motors. For us to find something way before catastrophic failure would save huge money in the long run. Then we could have the parts ready have the people ready and have the shut down time. When times were good shut down time was worth about $5000 a minute so we had to have our ducks in a row. For me at home it does not mater that much since it is just a hobby not a 24 hour a day 7 day a week operation.Predictive maintenance is supposed to be a huge money saver. If you can detect problems before they become big? I'm not sure I even understood this. If you find a bearing is bad, ok take an outage, tear it apart, replace the bearing, put it back together. So if you do that now or later where is the cost savings? I suppose if you do the work while you are down anyway then you could avoid an unexpected outage. I also suppose avoiding a catastrophic failure could prevent equipment from being wrecked. What else here I am missing? I feel like there are more use cases here than I understand.
I have a question for youbest forum going in my opinion!
