Just messing around. I have some forthcoming articulating arm projects coming up so made a tester. The ball is 20mm diameter. Stem is 10mm OD to fit a CF tube ID. The lugs hold M4 screws which grip the ball amazingly well, maybe the 3DP striations help a bit. I probably will increase the infill density on final print to give it some strength, but so far so good. I've seen some online models where a knurled nut squeezes down on the socket but that involves threads & whatnot.
