I think so. There’s a slew of photos.That looks like just the engine. Does the Generator come with that?
I'm curious what sort of power is created by that beast. Ultimately in kilowatts or even megawatts it should be possible to find a formula that calculates the required amount of fuel to generate that power.I think so. There’s a slew of photos.
Here's the copy from the ad:I'm curious what sort of power is created by that beast. Ultimately in kilowatts or even megawatts it should be possible to find a formula that calculates the required amount of fuel to generate that power.
Clearly there's no point in me buying it.Here's the copy from the ad:
Professionally deconditioned by CATERPILLAR Technician - Report Available Horsepower: 5733 hp. kVA: 5500 kVA Hours: 3755
Back when I was working telecom, we built a co-location facility in a former Macys store in downtown Atlanta. They put the backup generators up on the fourth floor. Three 12-cylinder Cat diesels similar to the one above. I was on site when they test fired them. The noise was astounding. We could see the windows shaking in the Hyatt hotel across the street.Clearly there's no point in me buying it.
Simply because I learned something important from a friend who wanted to burn used cooking oil in a Lister Diesel engine and generate power for the house. The problem is that you can't just dump energy back through the meter. BC Hydro has two limitations on feeding power back. One: it has to be done with one of their inverters that can be synchronized to the power line electronically. Two: no more than 5Kw is allowed to be fed back.
So much for a 25kW Genset for for that matter up in the 4 or more Megawatt range.
600 rpmI wonder what sort of RPM a beast like that runs, There must be some sort of self regen or cleaning, idling all day every day.
When we bought the kennel 21 years ago I promptly bought a 10000 watt portable from PA. It was important to have heat and water for the kennel in the event of an extended outage. Worked great. Kept it in the shop and had a small manual transfer switch. Never had a problem with it.
When we switched the kennel heat over to geothermal we needed to upgrade the genset to something bigger. If both heat pumps kicked in at the same time they pulled over 150 amps at startup.
On the recommendation of the local electrician I bought a 36 kw Generac running on propane with an automatic transfer switch.
It has been the biggest piece of crap I have ever owned. I had 7 service calls before it ever produced a usable watt of power. In the first year they replaced the coil packs, cam sensor, crank sensor, 2 control panels and finally the entire wiring harness before it would run reliably.
Warrantee expired after a year. The local Generac service company lost it's tech and never replaced him. For service I had to get someone out of Winnipeg, 5 hours away and of course he was on the clock from the minute the truck started so it would cost about 900 bucks before he got here. Only did that once to replace the transfer switch which had literally exploded. Ended up with a Saskatoon service tech who was closer but always too busy to make the trip. Generac had service guys in Regina, 25 minutes away but they only worked on the small portables, not the bigger stationarys. Local Caterpillar dealer sent a guy out once to replace another crank sensor. He ended up making 3 trips to get it running and when it died again 2 weeks later they said no thanks, we'll pass, you're own your own. Currently I am on my third transfer switch.
There is a Regina tech that will come out now which helps, sort of. He will only replace parts with genuine Generac parts. The starter failed last year and the Generac quoted price was around 2 grand. Got it rebuilt locally for a hundred.
This winter the power went out twice and both times the generator wouldn't start because it had to be installed outside and with the winter storms we got this year the enclosure would pack absolutely full with snow. I'm going to put a garden shed around the damn thing this year. Probably still won't start when the power goes out but at least I won't have to look at it.
I get worked up just thinking about this piece of crap.
They only thing worse than having your power go out on a minus 30 day is also having a generator that won't work when the power goes out.
