140mower
Don
It's good sand to get, especially if they are still having their annual sand castle competition and it's sunny. (And the wife doesn't catch you looking)Is that where you get the high performance sand from ? That's the sand I want
Did they put that on his headstone?Repair looks great!
My cousin famously said "I got married - I didn't go blind."
Beach sand isn't sharp enough. I gather up the stuff that comes off the coarse grinding wheel on my bench grinder.Nice job Tom!
Are going out to Miracle Beach to get some sand for inside to match OEM specifications, or are you going to omit that part?![]()
I figured that with the scenery and my need to live on the edge, the trade off might be worth the compromise. That and I figured that one pass through the gears and they should be sharpened right up.Beach sand isn't sharp enough. I gather up the stuff that comes off the coarse grinding wheel on my bench grinder.
don't get a bright idea to seal the case with a plate & partially fill with oil.
Yea, an oil bath is a much better system which is why I gave it a try. I attached a bottom plate just bonded on with gasket seal. That part sealed well. I ran a low oil level so the lowest gear was more or less slinging rather trying to semi-submerge more of the train. I think its my so-so fits of shafts into basically drilled holes in the apron. There are no seals or O-rings or cover plates like I could see on other lathe parts manuals. My shafts look kind of rough except where they wore in. I contemplated making better fitting bronze bushings like I did for the power feed rod block, but at that point I just moved on. Its not ideal but its actually somewhat common on this vintage. As long as I squirt oil in there often, the gears are wet.That's exactly how my lathe does it.
Heck yeah!Here's the finished repair.
All that is left now is to transfer punch, drill and tap the centre hole at final assembly. Probably over-kill to get oil from the front of the apron to the back, but the original casting did break, so there must be some mechanical stresses on it as well.
It's generally the metric bikinis that you want to follow.... Smaller and younger.....Looks great Tom, nicely executed.
Beware of the M beach sand, it's that cheap metric crap.
