Amazing metal printing
The $208 price on the original forum post seems cheap even just relative to your quote. Your $146 CAD for a pair of relatively simple (flange + short pipe) segments works out to call it $73 each. The forum header is 5 ports * 2 ends = 10 segments * $73 = $730 ...still not factoring additional length of funky path inter-pipe. I mean who knows unless one replicates the quote.
You might want to get a couple coupon rings thrown in the order to practice welding on. Everything I've read is that 3DP aluminum can be TIG welded not much different than regular stock, but apparently filler rod required. Autogenously is not recommended because of post cracking?
Anywway, look forward to how you make out on this, its exciting technology.
I wonder about the strength and integrity of metal 3D printed stuff? I am not in the know and am tinkering with the idea of getting intake manifolds 3D printed instead of the old farmer make up way I would otherwise do. Is SS similar to aluminum in that regard?
The raw base metal is fully melted together - it's not like particle board or sand with a glue holding the grains together. So it really should be strong. One problem with 3d FFF printing of plastic of course is the Z layers are not melted together as well as X & Y so fractures tend to happen on the Z plane. I wonder if there could be a laser precisely melting the surface of the bead just in front of and as the nozzle lays down the next layer. So the Z layers are fused together better? Sounds like a patent!
