@kevin.decelles Hi kevin, I'm down by Estevan. The machine and metal desert. Good luck finding anything down here. Unless, of course you want 20 ft. of what ever it is, you're out of luck. Thanks for the draft angle explanation, I'll do that.
Estevan? I've been there! You have no idea what's going on around you, if you think you are in a desert! LOL!
If you can't find materials, you are asking the wrong people, or at the wrong places.
Find an engine rebuild shop, and ask for pistons or manifolds. Most common alloy is 356 Aluminum which is a sand casting alloy. Aka: Pistonium! Set yourself up with a thermocouple to measure the temperature of the melt. Keep a log, noting melt weight, time, temperature and results, so you can have a chance at recalling just what you did right or wrong last time! Wear Safety Gear! The Tinsel Fairy (brought on by too much moisture, like, say, a spider, in the mold) is a cruel ol' Bitch, and God doesn't hand out more eyes!
Wrecking (aka Auto Recycling) yards are another fine option. At the worst, phone Inproheat in Edmonton and have them ship you some known alloy ingots! They can also provide ZA-12, or, at least, they used to.
Magnesium. The Acid Test (literally) is to scrape a bare spot on the casting, and apply regular Vinegar (Acetic Acid, 5%) to the cleaned area. Pouches of Vinegar from a fast food joint are really handy for this! Magnesium will burble and turn a sort of purple/brown color, making it easy to identify. Another way to identify it, is when breaking up the pieces. You hit an aluminum oil pan with a sledge, it breaks. Hit a Magnesium one with the same hammer, and it may KO you on the rebound! (personal experience, 0 out of five stars, do not recommend!) LOL!
Some search online will find you a bunch of different options for degassing a melt, Some guys use a gas wand, with inert gas, others use various materials that are submerged in the melt which flush the gasses to the surface, but the best thing is to simply get the metal up to casting temp ASAP, and pour it before it gets a bunch of time to absorb the gasses, thus the weight, time, temperature data suggestion above.
Been to the annual Model Engineering show? Kelly Tytlansvik (I even checked the spelling of his last name) is the organizer, and may be worth a blind phone call to. I really doubt there are many with a similar enough last name to cause a bunch of wrong numbers being found. Or ...
https://www.estevanmodelengineeringshow.net/
There is a pretty well established group of like minded reprobates up in Regina too, that may be worth contacting, and attending the monthly meetings. Guys that are into casting and hobby machine tool stuff across a HUGE spectrum! And guys in North Dakota, who also run an annual show.
There are more than just a few guys in that area doing everything from basic casting, to really high end machining (CNC Turbine engines, eg
, you just have to poke around a bit to find a few of them, and you will soon know a LOT of them!
