So if the pressure switch isn't unloading then that could cause too much current draw.Hold on, I edited my previous post.
Please read.
If the thermal overload is tripped it should only happen when current is being drawn by the motor. Therefore, using the meter and watching until the end of the cycle there should be an increase in current to heat up the thermal overload to cause it to trip BEFORE the end of the cycle.
EDIT - Unless, when the compressor is attempting to start a second time, and the motor is trying to start, can't, heats up, and trips the thermal overload.
Sounds to me like the system that allows the motor to start without fighting the high startup pressure isn't working.
No not yet. I don't have gear to test them.If that last scenario plays out, motor stalls attempting a second cycle, then @slow-poke will likely be correct about a failing start capacitor.
@David
Edit - have the capacitors been checked, yet?
Yes, it starts and runs exactly as I expect it to run. Cuts off at 135 psi.Ok
Have you ever been at the air compressor location to see what happens after it successfully starts the first time and before the thermal overload trips?
No, nothing like that. After it cuts off at 135 psi, I can drain the tank down to refill pressure and it just won't start unless I reset it. Which make me think that the overload is tripping when the pressure switch cuts in. Weird coincidence?Ok, but what about when it attempts a second cycle? Any signs of motor hum/buzz, hot to touch, before the thermal overload trips?
You have it exactly right.Trying to make sure I understand:
- first cycle air compressor runs as it should, reaches pressure setting, shuts off
- second cycle, no symptoms of a struggling motor/pump, no heat at motor, but fails to start
- at this point thermal overload is found in tripped position
Curious, if you were there after the first cycle and monitored the thermal overload trip button could you verify how soon after the first cycle it tripped?
And as soon as you notice it is tripped can you reset it right away? Normally, you have to wait for the bimetallic strip to cool (10-15 minutes according to the manual) otherwise you will be forcing the button.
I have the on/off switch for the compressor plug inside. I switched it on the other night and nothing happened. So I went to the compressor and pressed the reset. it would not stay 'pressed', I had to hold it down to get it to keep running.
Let me measure the current from start to finish tomorrow and also observe the overload switch to see when it trips.Unless I am missing something...
If you have to press hard on the button then you are forcing the bimatellic strip to make contact. That means it got hot enough to bend and needs to cool to relax into position for a normal manual reset.
But, if you can't observe ANYTHING at the compressor or with the clamp-on ammeter that would suggest abnormal operating conditions then in my opinion the thermal overload switch is not working correctly.
