I have a Fluke77III, doesn't look like it measures capacitance.
He found it under the seat of the car he just bought.
Maybe there is one under the seat of that car you just bought.
Only thing I ever got that way was an old but usable pair of vice-grips. But I only paid $5 for the car.
I do...Unfortunately I don't have an ammeter![]()
I also have a capacitor ESR meter. As capacitors age the Equivalent Series Resistance goes up. Normally only an issue with switching power supplies.I do...
On a 220V circuit do I measure both legs at once?
IIRC, you need to wire each wire individually
More telling what the current draw is just before the compressor cuts out or the overload trips. Current should increase as pressure increases, because the motor needs to work harder as the pressure builds.
Dumb question - are there ammeters for AC and DC? Or is an ammeter neutral?
From what I can tell it runs till the pressure switch kicks it off then it won't start again unless I reset the overload.
Tonight I ran it till the pressure switch kicked in, used my spray gun till it should have kicked in again but it never did.
OK I'll wrangle a kid to help me.I think it will be a 2 man job.
One person observing the meter and the other making the compressor cycle on and off.
What you should see at the meter before the thermal overload trips is enough "excess" current to heat up the bimetallic strip of the thermal overload before it bends and opens the circuit.
