Tool Air compressor fill time sanity check
Tool
Separated the two tanks this afternoon. Checked belt tension.
Turns out the belt was loose, likely because it was brand new so has worn in.
Cut the 0-60 psi time in more than half; 3 mins vs 1:22.
Time to 125 psi is now 3:22 on a single tank.
That’s a massive improvement.
Hard to believe a belt could be loose enough to cause that kind of difference! I'm amazed!
Bandit
Some of the quick connects are very poor for air flow, in hand with too small fittings and lines attached to them, a big problem causing not enough air, is leaks in the system, which also can over work the compressor/motor. You might have 120 psi static, but only be a getting lower pressure at useage point, due to small lines, poor connectors, fittings, etc. when in use. Looong lines are a problem too. A pressure gauge at the useage point can be an eye opener.
A funny thing this is the same for air, liquid, and electrical. Is what looks like a regulater on the lower tank bypassed before it goes to the upper tank? Might be some issues there if not.
Bandit
Not sure how much room there is from wall to the compressor, but air flow for cooling compressor head could be a problem also, as a lot of pumping time when using blasting cabinet.
David_R8
Scrapper of metal
It’s about 10” from the wall.
I’m planning to put a box fan on it when if I’m using it for prolonged periods of time.
Chicken lights
Forum Pony Express Driver
I’ve always been told that you can damage air tools by not giving them enough airflow. Probably not applicable to a sandblaster tho, but that’s the reason I run big air lines and the largest fittings.
