Active project - 1972 MGB
Nice. Not a bad deal either. They don't come up for sale very often up here.
Not one of the more desirable ones, though. The sought after ones are the early 1500s and the 67.5 to 70s 2000s with the solex carbs.
200 hp in a 2000lb car was a lot of fun in the late 60s apparently. Parts are getting scarce and pricey.
A set of solex carbs and intake manifold sold for 2900 USD last year. Car not included.
So when do you pick it up?
Now if you draw it from a front view does it still fit under the hood?
I think one solution is called a hood scoop;-)
So many ugly hood scoops out there, but a few nice ones as well.
I wanted to use a particular intake manifold on the Mustang that Edelbrock clearly stated does not fit under the hood of 65/66 chassis. Indeed with the hood off, the Cobra cleaner was well above the hood line. So I custom fabricated an oval drop base. That drop base and the Shelby hood was just enough. Looking in the scoop the filter was very close to the top of the scoop. Engine had a torque strap to stop it from hitting. Tight fit like everything else on that car.
