I picked up this 9" Utilathe (Thanks Phil) that's in pretty decent shape for it's age IMHO.
Note the headstock, tailstock, and tool post risers (3"). I want to delete those but unfortunately I'm missing the original 16T headstock drive gear and idler gear bracket.
This is the original gear train.
This is the gear train with the risers installed. Same gear ratio as the original just different sizes to accommodate the risers.
While in the process of re-assembling the machine and thought I would see if the main gears would mesh without the idler and risers installed.
Well.... they do within 0.09". That's how much I would have to shim the headstock higher.
The question I have for you all is. Is this a viable configuration in the first place (i.e. running with the idler deleted)?
