The CNC mill (converted manual mill) I acquired from @Janger (who previously acquired it from @Alexander) used HTD 8M timing belts on a variety of timing belt pulleys (some from cars I believe, some home-made). All the pulleys were mounted using set-screws on 'flats' on the lead-screw or stepper-motor shafts. While this works, it is prone to slippage due to the torque/weight of the tables. The set screws simply back-off and you have a pulley skip (which scores the shaft) which leads to a CNC crash. The X axis had a belt tensioner, the y-axis did not.
My goal was to mount the pulleys more securely, ideally using the 3mm key on the leadscrew, and using two-flats on the D-shaft on the stepper. I decided to start with the Y-Axis as it was the one I was having issues with, and the one without the tensioner. After doing some research on HTD 8m timing belt pulleys, I was very surprised as the cost. Not cheap, and not easy to locate a pulley with known number of teeth etc. The other issue was trying to find one with the right bore. I gave up on purchasing a pulley, and went next down the lost-PLA casting route. I had some decent results, but ultimately lost-PLA is a timely and costly process (propane/electricity/time)-- with a product that didn't have the precision/quality I wanted.
I took a further step back by reviewing the pros/cons of the Z-Axis 3D pulleys that @Janger had built. The design is logical, but the weak point was once again the set-screw contact to the shaft. With any undue torque/resistance, the 3D part cracks at the set screw hole. After staring at this for many hours, the answer I believe is to increase the contact area from a single point (set-screw) to as much surface as possible. I decided to built a steel 'collar' that fit on the shaft, and use a series of key-ways to mount a PETG or ABS 3D printed pulley.
For the Y-axis I needed 2 collars, one for the 5/8 shaft of the y-axis lead-screen on the mill, and the other 14mm for the stepper. The lead-screw collar also needed to include a recess for a thrust bearing , an internal keyway in addition to the 4 external key slots. The stepper collar was more simple, a 14mm bore w/the 4 key-way slots.
I don't have pictures of the lead-screw collar before I mounted, but here are pics of the stepper side plus pics of the final product (with belt tensionor)
Picture of the pulley (black PETG w/ 1/4" keyways
Picture of stepper collar/pulley mounted w/key-ways full
Picture of the other side and the finished product
So for results? Awesome! I was skeptical that the PETG would grip the belt as well as it did. I figured it would slip or stutter. The 3D models I found are perfect matches for the belt profile, and the grip is great. Before I did this mod, the best I could get out of the Y-axis reliably was about 10 in/min jog speed. With this mod I'm up to 16.2 in/min. This mill has the usual table, but also has a sub table that allows the top table to be turned. This adds weight. Add to that the Kurt DX-6 vise at ~75lbs and there is considerable mass.
overall, very pleased so far, and I have a great consumable part that can be replace at will. The 4 key-way idea came to me as I was wondering how I would best machine a collar to fit the existing pulleys. By using the 4 key-ways, the pressure/torque is applied across 30-40mm of 1/4 key x 4. I know the PETG can withstand pressure, as it is tough to crush in the 1-ton arbor press. In this configuration I think it should last quite a while.
The belt tensioner was another piece of steel from a John-deere discer I salvaged. Great stell to work with. The collars were made from 2" diameter 12L14 which I very nice to machine and will be good for this application (low impact/hardness required.)
The other plus with the shaft collar is that I can experiment with different size pullies, simply keep the internal sizing the same. The original setup used a 15T pulley on the stepper, I couldn't find an STL for 15T so went up to 18T. I also then went up a similar ratio on the lead-screw to keep the ratio similar to before.
As for lost-PLA, I may go back to it, but first I'm going to convert the other two axis to a collar system.
Summary of machining techniques used:
Lathe: Turning, boring, drilling, facing
Mill (w/dividing head) slot cutting
Shaper Internal 3mm keyway on the lead-screw side.
Vertical Bandsaw: cutting of key-stock
Arbor press: pressing on bearings for tensioner
Supplies:
2 pieces 12L14 75mm in length
set screws (x4)
3mm key (x1)
1/4 key stock (x8 pieces)
Replacement thrust bearing
1/2 Bolt (tensioner)
5/16 bolts (tensioner)
HTD 8m timing belt (www.vbeltguys.com -- great site, cheap belts) 568mm x 12mm
PETG (I use/like the product from Spool3d.com)
3D printer - stock Creality Ender Pro 3. I bought this a month back and it is printing these pulleys stock out of the box.
Supplies:
set screws (x4)
3mm key (x1)
