Several years ago, RapidChange announced a rack-style tool changer for ER20 spindles. These are typically driven by 1.5-3kw motors via a VFD.
Initially I was on a short list to get one at heavy discount if I could get it working on PathPilot. I couldn't get it sorted so passed on the deal. No point spending money to have it sit idle irritating me every day.
Fast forward to now.
RapidChange's patent application was seemingly rejected/returned for regrooving twice. It is now marked as Ceased which I believe means they stopped working the patent. And their pricing has gone up considerably, to the point where I won't spent the money. (US$800 for a full featured rack version).
Then up pops a YT video from BenchWorks/CNCWoodShop in South Africa. He has a 3D printable version that is more up my alley, esp. since my X2D is doing such a great job of printing anything I throw at it. So I purchased the fulll file set, CA$65. Add in some springs, long M6 bolts, 2 servo motors for the cover drive and some sensors. From AliExpress of course.
The files print perfectly. Roughly 4 hours per pocket at 40% infill. The Nut Block (that holds the ER20 nut) is suggested to be printed in ABS, which I substituted PETG for now.
A few hours with the
LinuxCNC RapidChange M6 code resulted in a working version for PathPilot. All of the changes are in the .ini files (and I still have to add an ATC.hal for the door cover.) No actual code needs changed in PathPilot, it is a replacement of the M6 remap. There is still a gap in editing the tool.tbl file that maps tool numbers to pockets but I think I know what to do for that.
While waiting on the springs I made up a weaker version and tested a tool change. The tool tightens really well with just one 'strike', hand wrenching only move the wrench a tiny bit more. Dropping the collet also works. I'll likely add a second strike for the collet load.
No videos yet, I am waiting for the real springs as it is a bit tenuous how well the nut engages the pocket at the moment.
One observation about the difference between RapidChange and BenchWorks versions: the RapidChange one is machined out of UHMV and or Delrin, and as a result is more compact. I think the BenchWorks one could be redesigned to a slightly more compact but for me it is good enough for now.
I am not going to get into discussions of whether the tool holds well enough for cutting aluminum or steel, there are plently of videos from the RapidChange community on YT that demonstrate the effectiveness.
This video should be a good indication that the collet is tight enough, it was a contant barrage of questions when the tool changer was first announced. The
RapidChange YT channel has much more, as does the
BenchWorks one.
The pic is of the incomplete build, stuck in a vise while I wait on parts.
