I seem to have sparked a firestorm - which was not my intent.
I guess some theory / background for my comments seems necessary: All AC induction motors work on the principal of magnetic induction - hence the name . What that means, is that a changing electric current, generates a changing magnetic field in a sine / cosine relationship. Positioning 3 (or multiples of 3) circuits on a wheel allows the linear attraction of one magnet to another, to produce a rotation force.
When a rotor is under 'no load', then it moves 'immediately' in response to the next magnetic attraction caused by a new current in the next coil.
When a rotor is under some load, then it's movement towards the next position is delayed in proportion to how much load it is under. This time component is how the motor develops power. And also how the increased current is caused. The more load the motor is under, the longer the time lag between the 'ideal' movement of the rotor and its actual movement. This lag dives current, power and heat.
For anyone familiar with clutch plates, it's like a backwards version. With a clutch, the engine makes all the power that it can, and then as you push in the clutch, some and then more of that power is transferred to the wheels. An AC induction motor works the other way. It makes no power at all until some load is applied.
For many motors, the largest load that they will ever see is when you flip the on switch. Overcoming the inertia of the rotor and anything attached to it. This phase is called inrush. And is made much worse by a lack of capacitance within the motor itself. Many motors use things like fly clips to add capacitance at low RPM and switch them out as RMP increases. VFD is a much better choice
This message already feels too much like a lecture, so I'll stop here. On the other thread I burned a 100$ bit because I engaged it too slowly
If any of these 'bad' motors are anywhere in the GTA, I'd be glad to take it and wire it up
