3 Phase Motor Wiring
Picked up this 3 Phase motor today.
Of course none of the wires are color coded. Just numbered....
I don't know how to interpret this wiring diagram???
This is how the wires are setup currently. 4-5-6 are joined and capped. 1-7 are joined and capped. 3 is capped. 2-8-9 are available for hookup. I want to hook this up for 220V.
I found this descriptions for Y wiring on the web.
Make the connections for low voltage, 230-volt wiring. Connect motor leads 4, 5 and 6 together. Connect motor leads 7 and 1 with the black L1 conductor. Connect motor leads 8 and 2 with the red L2 conductor. Connect motor leads 9 and 3 with the blue L3 conductor.
Which makes some sense of the wiring info plate I guess.
Sound right to you?
Thanks,
Tom Kitta
just follow diagram for 240 - 4, 5 and 6 together in a cap
9-3 line 1
8-2 line 2
7-1 line 3
flip line 1 and say line 2 to change direction.
kevin.decelles
Ah the memories. Bought a 3ph motor at an auction, opened it up at home, found 9 grey wires, no markings, no numbers. This turned into a two-drink Saturday night special.
Learned a lot about how to determine if the motor is wired for delta or wye. Great web-sites/videos on how to do this are out there.
Delta wiring
WYE wiring
