Life has been crazy here and I finally was able to get some time on Tuesday to scream up to Calgary and pick up this King mill. They were very pleasant and agreeable in letting it sit along a wall in their shop.......a 3 bay 2 storey building full of some wonderful pieces of equipment that would be a blast to play with...... Anyway, we wheeled it out, plugged it in and I took quick good look at it.......but no photos!!! What was I thinking???
It looked good. Table, bed movement in both X & Y felt great. Very little backlash on X and a bit more on the Y, but it felt quite loose like the gib just needed some adjustment. Both the head vertical movement as well as the spindle felt good and smooth. It has a Z axis DRO that appears to be a scale similar to a digital caliper that is mounted inside the casing and attached to the spindle. So I don't think it will read the movement of the head as it moves, only spindle movement. The table has some very very tiny nicks here and there, but most of what I could see in the photos above is dust and not imperfections.
It took me a bit to figure out how to turn it on. The forward/reverse switch cannot be in neutral and had to be in either forward or reverse to get the spindle speed display to stay on. So switching from forward to reverse shuts the machine down, and the emergency stop button needs to be reset....after putting the controls into F or R. Strange!! Anyway, I figured it out and ran the machine at all speeds in both reverse and forward in both High and Low range. Sounded good and the spindle speed display worked great...... that will be a nice little addition.
They had mounted a riser under the base to raise the machine by 4 inches or so that is made out of C channel so that it can also be use to pick up and move easily with a forklift. I backed my truck into one of their bays and they loaded it in. Wth all the rain that we have been having on a daily basis these last well.......whole spring and summer so far!!!...... I brought a roll of shrink wrap to try to protect the head/bed/column area from moisture should it rain. Got it wrapped, strapped to all for corners of the truck bed and took off for home........well, after a quick visit to Busy Bee.
While I drove up to Calgary in the rain, I did make it home without any and as I backed into my shop door to unload it started up again. I've only had time to lift it off my truck and set it down there right at the door. I have yet to rearrange my shop and organize things a bit different before I will get any chance to play. Hope that doesn't take another month!!
Will get pics as soon as I can get some time.
