$1000 handwheel
Johnwa
He junking plastic handwheel on my bandsaw vice started slipping on its hub so I decided to make anew one. Several hours later and there’s still lots to do. If I valued my time it has to be worth at least $1000. LOL.
Johnwa just think on all the fun you've had doing it, beside much better than chasing grandma around the house right. LOL
Almost finished. I used a router round over bit to get an approximate radius on the wheel. I ran the spindle backwards to get the side next to the chuck.
The closer handle came out really well. Lee Valley rivets?
I've been wondering how well the router bits would work on metal, have you tried them in the milling machine?
Chasing is one thing, catching and then remembering what to do when (if) caught is another. lol
I had a 3/16 brass rod so I knurled a section and used that for rivets. I stuck everything together with jb weld.
I used 4340 for the wheel so I ran fairly slow, cut with each corner of the bit and then the center section. Repeated that a few times until it was close enough.
I’ve never tried it in the mill. The interrupted cuts could be a problem. It would likely be fine with aluminum though.
Yes Yotabota there is a tooth ferry, you may recall my Spindle square post back in May.
https://canadianhobbymetalworkers.com/threads/spindle-square.3383/
Just took this photo so you could see how I rounded the end of my spindle square with 1/2" shank woodworking carbide router bits on aluminum. My Craftex hobby mill/drill did the job nicely says I which was running about 550 RPM in a single pass. Should I be called upon to do it again I would likely try running at a higher speed or do a very light finish pass, really unsure only because I've not tried that.
So the answer is yes for aluminum and most likely brass.
