YYC: Wazer Waterjet Cutter
Wes D.
Wazer Waterjet Cutter (https://wazer.com/) purchased in 2019 and with approximately 250 hours. Pump oil changed after the initial 50 hours.
*** Please check the input water specifications before considering: https://wazer.com/product/tech-specs/ ***
The machine needs a fairly consistent supply of water at a high flow rate, please take the time to fill a bucket and check some pressures.
The machine is capable of cutting a wide range of materials (https://wazer.com/materials/materials-specs/)
* Two replacement cutting beds
* Two replacement vibration motors
* Stand/Leg add-on
* Original two flood sensors
* Replacement nozzle
* Two Replacement filters and original tools, save for some hose clamps
* Manual
* 5 x 25kg+ water jet grade abrasive
Asking $9,000
Wes D.
Is this the same model You Tuber Keith Fenner runs?
It appears so. As far as I know there is only one model, although I have heard of some people getting parts replaced and the newer part is different. The two I have heard of were the door strut pistons and the low pressure water pumps.
