Elektrishun
...how often do you try to hide your mistakes?
I am not a professional woodworker but I did spend a lot of years building numerous projects of varying degree of difficulty. One of the common sayings I heard/read in the woodworking profession was:
"90% of woodworking is knowing how to fix your mistakes."
Now that I am getting more into the world of making mistakes while making metal shavings I was wondering if there is a similar philosophy when working with metal?
It seems to me that the tighter tolerances often needed to make something with metal wouldn't allow for much room for error unless your churning out paper weights or catapult ammunition.
Would like to hear from members how often they need to fix an error or does 90% of errors in your machining end up in the scrap pile?
I assume a one time hobby project on manual machines vs a professional run of several like pieces using CNC equipment might change how you answer.
Thanks
Thanks
